MTNL Broadband: How to Setup Bridge Connection NOOB
  • Thread starter Thread starter qsahmed
  • Replies Replies 14
  • Views Views 5,395
let me say this very clearly to you.....in bridge mode NAT is disabled.... so think about what u are claiming.Check firewall or configure ur torrent client:P
hehe.. As Mac said, you need not open any port if you bridge with your pc. Some firewall/internet security may be blocking it. can you see a green icon on the bottom? check firewall/internet security ! it has hardly to do with torrent client (unless you screwed it up) !
well reset got back to default settings but net is not working can u tell me the settings which i should use
@tufnut
Settings for DSL-502T modem. with screenshots.
D-Link Settings for Broadband
or this
2.Socrates?s experience: Configuring the D-Link 502T router for MTNL Broadband Do it yourself
or Everything!
3. Download
k.... got the net working but the net is not connected every time i have disable and then enable the connection to get it working and the modem won't start as it will just show power and nothing else i have to start it over and over again to get it working never seen this before its for the first time i am having such prob
