hi,
i have mtnl connection for last 10 months and using a private modem COMPEX MRL21E.
it worked fine for first seven months or so but from last three or so months i am facing severe disconnection or not connection.
as the modem is not able to either connect or the connection drops frequently, but sometimes it works fine for hours but when i restart the modem it fails to connect again.
the mtnl delhi guys as always blame the customer hence they blame my modem (they are saying that this modem has some inhereted problem and it will not work fine, but it worked for seven months), as it was in warranty i changed it three times(this time got a new one).but the problem continues.
now the mtnl guys on my persisting complaints had provided me a modem from there side for trial period 4 couple of days, its MT882.
the problem with this modem is that i dont find any major improvements.
prob with this mtnl modem:
1)sometimes all the lights are up but net is not working and ping shows destination unreachable,
2)when i check mtnl usage, it shows network disconnection at infrequent hours, 2,3,4 etc.
my queries are:
1) is the problem is really with my modem (as now i have a brand new one from the company), if yes tahn can it be solved via settings.
2)if it cant solved than should i opt for an mtnl modem, and this frequent disconnection from mtnl modem can be solved.
3) if i opt for mtnl should i choose for wireless adsl modem from mtnl one as Netgear WGR614 is only a wireless router and with this i will be needing a adsl modem as well.(correct me if i am wrong).
after so much trouble my friend told me abt this site, and this is my first post.
i need some answers as i am in deep trouble and need something to fight with these mtnl folks.
for ur reference i am posting images of my modem COMPEX MRL21E
http://img77.imageshack.us/img77/5842/50618201qn1.jpg
and its status shows
Rate (Kbps) 2047 260
SNR Margin (dB) 23.1 32.8
Attenuation (dB) 31.0 0.0
Output Power (dBm) 2.5 6529.6
Super Frames 1762 1756
Super Frame Errors 0 544
and the one provided by mtnl MT882
http://img112.imageshack.us/img112/5406/19879510ah5.jpg
i desperately need some answers.
hope someone could come 2 my rescue
thanx in advance
my queries are:
thanx in advance
