mtnltriband
Dostidilse,
I have gone through the diagram, I understood it ...thanks for the same
When MTNL will get DC and I will shited to RELIANCE my PC ip will also change???? and in that case the servers I am connected to will recognise it as a new connection and my session will timed out??? ( in case if server at other end has a load balancing setup then it may recognise new IP as a new connection....I am be wrong )
Please go through this link....my doubt is based on this link....
So if I am connected to trader terminal.....with MTNL and connection fails.... I will be still connected to internet with RELINACE due to load balancing....but then I will be logged off from my trader terminal due to new IP of RELIANCE.....in case if IP address of my machine changes.... since the trader terminal server msut be having a load balancing set up which will recognise new IP as new connection.....
while doing internet banking also my session will timed out coz of change of IP ....from mtnl to reliance.....
but if there is no change of IP or....sessions will be not timed out...i wont be logged off and then its OK to go for load balancing .....
PART 2.
I have found a website,
LINK
Please go through it......it tells about load balancing without any router or any physical device....just a small scrip works......pls confirm is it possible.......i read many times but unable to decide whether it will work or not......
PART 3:
Will this software solve my problem
PART 2.
LINK
PART 3:
