Hi,
I need some urgent help on multiuser (PPPoE) configuration for my Nokia Siemens SL2_141 modem. I know this is a known issue (at least some variations of it) - however, i have tried searching in multiple forums, logged a complaint with BSNL but the issue is not yet solved.
Initially my modem was configured as Bridging (Connection Type) and I could connect only one device (either wired or via wireless) at a time by using the dial up.
Later on, as advised in the BSNL site for multiuser configuration, I have setup the connection type as PPPoE and I could connect multiple devices (laptop, cellphone, etc) at the same time via wireless - i do not need to use the dial up anymore. The problem is with my desktop computer which is still hard wired with the BSNL modem and i am not able to connect to internet. The LAN connection is good - however there is no internet connection. When i am trying to use the dial-up (ideally i do not need to) from my desktop, it is giving me an error 676: Phone line is busy. I believe the issue is due to a simple configuration issue - however, i am not abel to figure it out. Please help. The details are given below:
ipconfig:
Wireless LAN adapter Wireless Network Connection:
Link-local IPv6 Address . . . . . : fe80::19af:42ca:f1ec:a1bd%19
IPv4 Address. . . . . . . . . . . : 192.168.1.3
Ethernet Adapter Local Area Connection:
IP Address. . . . . . . . . . . : 192.168.1.12
Modem Configuration:
WAN Setting:
Port/Vpi/Vci: 0/0/35
Con Id: 1
Category: UBR (without PCR)
Service: pppoe_0_0_35_1
Interface: pppoe_0_0_35_1
Protocol: PPPoE
Encapsulation Mode: LLC/SNAP-BRIDGING
Igmp: Disabled
QoS: Disabled
State: Enabled
Authentication Method: Auto
Bridge PPPoE frames between WAN and Local Ports (Default Enabled): Checked
Enable NAT: Checked
Enable Firewall: Checked
Enable WAN service: checked
IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
DHCP Server Enabled -
Start IP: 192.168.1.2
End IP: 192.168.1.254
Please let me know in case you need any additional details.
Thanks in advance.
D Igneous
ipconfig:
WAN Setting:
Con Id: 1
Protocol: PPPoE
Igmp: Disabled
QoS: Disabled
State: Enabled
Enable NAT: Checked
Thanks in advance.
D Igneous
