My BSNL plan gives me too low side
BSNL
My BSNL plan is "BBG Combo ULD 999" for which I should get "Upto 4Mbps till 8 GB, 512 Kbps beyond 8 GB". But when I took some speed tests including that of BSNL, the results were as low as 10kbps and max to 60kbps! What should i do?
Should i change my broadband provider?
Or what should i do?
i do not think you can browse the web at 60kbps today. this forum would not even load for you at those speeds. please post a speedtest result from speedtest.net.
to be honest speedtest.net would not load at 60kbps :D
unless you meant 60KBps which would be more like 480kbps.
still nowhere close to 4mbps.
lol here are he results.
well if you are fuped you are getting correct speeds 512kbps means 64KBps.
