I have iBall Baton ADSL+ modem. I have BSNL 1199/- plan.
I have problems:
ADSL after some time starts blinking and not being stable.
If ADSL after 2 or 3 minutes get stable it is for sure on 256kbps downstream and 64 upload stream.
What have I tried ?
I have lodged a complaint in the BSNL for 5 and more times for the ADSL, not a stable problem.
BSNL replied - They have changed the port and it should be sorted.
I have called BSNL lineman also for checking the line is clear or not?
Lineman reply: Line is clear.
I have asked BSNL why this happening ?
BSNL reply: Your modem must be faulty change it.
My reply: I have replaced a modem.
I have configured modem thrice by helping of the computer engineer.
Computer Engineer : everything is clear by our side and it should be fine from our side. It has a problem in BSNL side.
What I have seen in statistic table as under:
Downstream Upload
SNR Margin 12.5 8.7
Line Attenuation 40.0 32.3
Data Rate 1076 313
Max Rate 3448 385
CRC 1231 3791
Help me to figure this out problem. In Advance thanks.
I have problems:
What have I tried ?
Downstream Upload
SNR Margin 12.5 8.7
Data Rate 1076 313
Max Rate 3448 385
CRC 1231 3791
