Broadband - Help & Support
quote
SNR (Signal to
Noise Ratio)
This is a bit like
television reception. A high SNR means you're getting a good clean
signal with no static or interference. A low SNR and broadband signal is being
drowned out by noise. Watching a bad TV picture may be annoying, but you can still
use your TV. With your broadband, lots of noise can quickly lead to a complete loss of your connection. SNR is not usually provided as a line stat, most hardware
will show SNR Margin instead.
Line (Downstream) Attenuation This describes the loss of your broadband
signal over distance. The greater your distance from your local telephone
exchange, the weaker your received signals likely to be. If the quality of the
telephone cable is poor, this can also increase attenuation.
* 75 dB+ Out of range for broadband
* 60-75 dB up to 512kbps
* 43-60dB up to 1Mbps (higher speeds
with MaxDSL)
* 0-42dB up to 2Mbps+ (higher speeds
with MaxDSL)
A dB (Decibel) is a measure of sound intensity. It's a logarithmic unit, so an increase in 3dB is equal to double your original intensity.
Unquote
Hope you have connected all your telephone/s after the splitter.
