my snr and attenuation
  • Thread starter Thread starter manuab123
  • Replies Replies 28
  • Views Views 4,104
Provide Log File of Modem. (Asking Second Time o_O)
What is your State in India?
now the exchange had did something speed increased to 8mbps but while downloading from any device its coming upto 1mbps
i think its about the telephone line wire problem and change into a new wire.Suggest any opinion about this situation.
there may be some issues with the line itself. tell them to check the line. it may not only happen with the telephone wire in your premise it can also due to issues with the line pair that is coming from the exchange.
You need to have ADSL2+ for sure with Annex M enabled. Set the router accordingly.
The line is configured for 4 mbps from bsnl.
Check if you are having any firewall which restricts you to 400 kbps...
If problem persists check the line for disturbance...,
what do u mean by annex m. i have bigger line attenuation , i am staying 1km from the exchange
Are you sure about the line wire is the problem for slow internet speed
since you said there was some working going at the exchange that could also be one issue. i had the same problem a few months back and when i booked a complaint they said some work is going at the exchange that is why speed issues and disconnections issues happen. they can happen due the port your connection is in the exchange and also due to the issues with the line.
