NAT problem on Exatt (Vile Parle / Andheri)
  • Thread starter Thread starter nchinmay
  • Replies Replies 4
  • Views Views 2,516
nchinmay
Times Warner
I stay near Shaan and Suncity theatre and have a 256kbps unlimited connection from advision(Log2space). The server address is 202.63.174.250
This is also seen as my IP address it i do www.whatismyip.com . However my IP is dynamic and changes everytime I connect to the net. This is the current ipconfig
IP Address. . . . . . . . . . . . : 172.16.11.150
Default Gateway . . . . . . . . . :
PPP adapter Connection to advision at advision:
IP Address. . . . . . . . . . . . : 221.128.181.95
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 221.128.181.95
The address in red is my dynamic ip address. I use Trends PCcillin for antivirus and firewall but I have allowed both incoming/outgoing for TCP/UDP for Bitcomet 0.6 on all addresses and all ports. I still get a NAT error and cant connect to remote connections but only local ones. This greatly affects speeds. From what I searched on net I need o reconfigure ports on my router but i dont know the router address. Is there any other way?
Or is it a problem with my computer? I have WINXP whit SP1 installed.
I also formatted my system today to eliminate any chance of problem with my machine. But now I am sure my ports have been NATed from outside.
Anyone has a similar problem or a solution to it?
I have the same problem. I have net9online. I the ISP to get my ports forwarded but they will not do it. I use Azerus and get a NAT error. But you can download at slower speeds. I dont know how to get around this issue.Anyone, any ideas !!!
Originally posted by max@Dec 9 2005, 10:46 PM
why the multiple posts nchinmay?
[snapback]35048[/snapback]
[/quote]
Sorry that was a mistake. Can I delete this thread?
