Need Firm ware for Beetel 450TC2
  • Thread starter Thread starter naren008
  • Replies Replies 11
  • Views Views 18,756
chennai
bsnl
i bought a Beetel 450TC2 modem from a person who his known to my friend, later 1ly i came to know it is airtel modem but my ISP is BSNL, By watching youtube tut i configured the modem but cant do nothing with wifi settings. I asked him for that he told me he had firmware by updating that u can use wifi i send u but he absconded cant able to contact him or by friend , i using modem without wifi for 2months
So please any one send me firmware to me, give me a guide to update it.. my mail id: narendhiran8288@gmail.com
I do have firmware file for my Beetel 450 TC1
Beetel-TM4-0Q-020_20100628(With-Without CAS)
Not sure if it is compatible with your modem.
Hi,
Dont mean to hijack the thread, but would it be possible for you (or someone else) to share the Beetel-TM4-0Q-020_20100628 firmware. I am struggling to connect my beetal 450 TC1 with my BSNL connection. I am still trying to connect via LAN, but post that I gather that I will need to downgrade the firmware to be able to modify the wifi settings....
Please help!
Thanks!
yuga said:
The beetel tc2 is actually a TP-Link one . In an another thread i have given the model no as well as how to upgrade the firmware for beetel 450tc2 . Please download the firmware from
http://www.tp-link.in/resources/software/TD-W8951ND_V5_131104.zip
Hello guys, new here. Got a 8 Mbps Airtel BB connection last month and its been alright. Speed is almost always in the 8 Mbps region, d/l only. U/l speeds are a pathetic 800 Kbps or lower.
But anyway, here's the issue:
After being annoyed by the lame range and frequent loss of ADSL sync, I tried to update the firmware to the one you linked. But, after getting to 100%, and then resetting and restarting the modem, its the same firmware as before. The firmware does not change which leads me to think the modem is firmware locked. I even tried the 30-30-30 reset cycle and then tried to update the firmware again, but no luck. Why do these ISPs screw with and limit these pennyworthy boxes anyway? :pissed-off:
Any pointers, has anyone dealt with a similar situation?
Cheers!
Hi Uberjon,
Thanks for sharing the link for updated firmware for Beetel 450TC2. With pre-installed firmware, I was stuck with DynDNS for only DDNS provider. Finally with firmware you pointed to in this thread, now I have option to pick no-IP as alternate to paid service of DynDNS.
-Sanjay
