need Help no internet after 5 min on reseting and reconfig
  • Thread starter Thread starter Hackster
  • Replies Replies 3
  • Views Views 649
Badnawar
bsnl
I try everything and check every post I am posting all the screenshots if anyone can help plz do thanx in advance. So after resetting the router internet work for like 5 min after that it will stop all lights on the router is green
PON info looks okay. Suggestions -> change MTU and uncheck all port bindings. May not be related to your issue but just try these things and test.
@sloj how MTU where i look everywhere there is no setting name mtu like there is no internet connection for me on my pc so can't check on cmd ping 8.8.8.8
Look at the first screenshot. There is MTU above the username. You said internet works after resetting the router, do that. If it is an issue from exchange then you won't have internet. May be they are doing minor maintenance.
