You're welcome. With stock firmware this would have been a very simple set up but because DDWRT has such a lot of options, it's easy to go awry somewhere.
You may need to fiddle around with the settings to resolve the issues, most probably some packets being dropped due to some settings. Check if there's any packet loss at pingtest.net Also see if the problem exists on all connected devices or just one. You may also need to look at the mtu settings on the router.
Also check by giving static ip on the laptop in the 192.168.1.x series with gateway 192.168.1.1 and with DNS 8.8.8.8 & 208.67.220.220 also defined on the laptop. If the problem persists you could also try going back to the stock firmware.
