Need info on Wireless access point
  • Thread starter Thread starter Gavco
  • Replies Replies 3
  • Views Views 2,265
Gavco
H500
guys,Pls provide me your kind suggestion on below inquiry. Need to buy a Wireless access point for my D-Link Router, can someone suggest me a wireles access point which can give me a distance range of 400 meters I have dlink GLB-502T ADSL router Thanks:)Waiting for your advice and suggestions
400 meters almost 1200 feet distance not possible. without
antenna boosters etc.
Try with your cordless telephone and try
paging your base unit ( if 2.4 Ghz unit better) If successful ,
give feedback. Usually WIFI router have a range of radius 30 feet .
Buffalo units with higher power may increase the range.
Height/location/obstructions etc may make a difference.
setup : telephone modem glb502T== WIFI router == laptops
Para two:
Alternate use data card from BSNL.
Check facility available in GOA>
Bharat Sanchar Nigam Limited - BSNL Data Card - High Speed Internet - Anywhere - Downloads
not official site.
well most routers "theoritically" support 400 metres OUTDOOR.. so it all depends.. if possible test it out with somebody else's wifi router first..
