Need Screenshot of SITI Cable Broadband Docsis Modem Web Page
  • Thread starter Thread starter raman07
  • Replies Replies 4
  • Views Views 3,857
Netplus
Can anyone please post their Siti broadband modem web interface page? I need to buy cable bb Amplifier. So i want to see the frequency and channel bonding info. Please post your screenshot.
It should contain downstream and upstream channel stats.
Here is an example :
Thank you, By looking your downstream power value. Seems like your connection is not so good. Do you face any speed or disconnection problem? I read on internet that downstream value should be between -15dBmV to 15dBmV and for more better connection it should be between -8dBmV to 8dBmV. Or you can say it should be near zero. But your go up to 19dBmv.
upstream value should be between 36 to 55 and for better connection it should be between 40 to 50. Your seems just ok
Do you face any problem with your connection?
Do you use 100mbps plan? Can you please post screenshot of your speed?
And ping result to the 8.8.8.8 server?
Well i can not really say that your stats are bad. I just read that on internet.
If high dbmv power is causing you issue, you can try reduce it by adding an extra splitter and inserting the cable that goes to your cable modem into Tap. Main cable coming to house goes to In and Tap to cable modem. If your connection already working fine, no need to do anything.
Example splitter:
Example image in the OP post has SNR too low. It should be between 35-45 db. Lowest is 30 db and below it, it will cause frequent disconnection.
2nd image SNR 51.5 db is maybe bit high but if its not causing issue, its ok i think.
