Ups are pretty useless get an inverter. I used a ups with inverter so ups battery was only to prevent voltage fluctuation during power cut still the ups battery would go bad after 1.5-2 years. After getting laptop I ditched ups completely.
You can check on the back of power adapter.
It will say something like 12v=1A or 12V=1.5A . Also you will have 2 Voltages over there AC(Input) and DC(Output)
You need to look for the second one which is output
The UPS you are buying should have at least equal to the Ampere(1A or 1.5A) of the adapter or above it(like 2A on the UPS) is also fine.
The one you have selected should work for you as its 2A and 12V. Many routers follow this standard. But better to check sometimes as in a rare case we have 17Volts too
