Need the Fastest speed plan with budget of approx INR 1500
  • Thread starter Thread starter poseidon
  • Replies Replies 10
  • Views Views 3,329
poseidon
BSNL and Airtel
Hi guys, I am having BSNL unlimited 256 kbps home plan but the speed sucks. I am power user and spend 14 hours in on my system :) and speed is very important for me. I am looking to upgrade my plan so can u ppl please tell me the best BSNL plan in terms of speed and bandwidth(both limited and unlimited) with a budget of INR 1500 to 2k (at max). Thanks
Thanks
IF you are just looking at BSNL plans, why dont you have a look at BSNL page itself rather than making someone else to do the job ! they clearly have mentioned about all plans like 900plan. They have even mentioned the speed too !!
Bharat Sanchar Nigam Ltd.
poseidon bro how much data approximately do you download ?
Because all BSNL UL Broadband connections have 256kBps speed.
So check for download/upload limit first.
Hi Appu, I have surely looked at the plans of BSNL many times but I want to know what people's opinion is ? The statement "upto 2mbps" is just too vague and I have heard ppl saying they it will always be close to 256 kbps only.Also How fast can be business plan as compared to home plan for same 256kbps line ? BSNL has just mentioned the rates but I want to know what people think :) This is what we have BBF.in for, right ? :)
up to 2mbps mean u can get near 2mbps,i never found myself close to 256kbps,if that will happen i will change plan to 900ul,so home 500 is good if don't browse too much,or get home1000 for more 5GB limit,but u can daily download around 4GB for sure,i never downloaded below 3.5GB in 6 hours nu,so u will get speed like 1500 or 1900 kbps in those plans..
""To provide a cost effective service - all ADSL services are contended (shared). These contention ratios are applied in the backbone and international part of the network. A commonly applied contention rate is 50 : 1. All customers are guaranteed the plan rate up to the local exchange or the ADSL equipment to which they are connected. On the shared part of the network a 50:1 contention ratio would mean that a 2 Mbps connection would be shared by 49 others. In reality this is very unlikely to happen and the customer would find the connection much faster than dial-up modems. ADSL relies on individual users not making unreasonable traffic demands on the network to provide fast access speeds for all. If you are not getting the speed you expect, it can be due to the contention ratio but also to many other factors including the congestion at the remote site you are accessing""""
.I am on Home250 tariff plan upto 2 Mbps
speedtest.net/result/231472054.png mumbai
speedtest.net/result/231472371.png Adelaide
I am already having BSNL and airtel connection so I can use them if I runs out of BW at the end of the month but will surly need around 10 GB per month
Regards
mumbai
Adelaide
Hi, it is the night speed ? because I can't even imagine getting such speeds ?
The speed test shows the time in GMT. Please add 5 1/2 hours for IST.I`will try to post results tonight for both Airtel and Dataone. But the speed from the server you cannot expect/ need not be same. A download manager will show the actual speed of download. In Airtel it almost stabilises between 20 KB/sec to 32KB/sec. for me. (*conditions apply !)Para two : One way to keep the D/L within limits is to use IE sparingly. Use FireFox Browser with Adblock Plus, IETab , FlashBlock and NoScript add ons. As I am not aware of the nature of your downloads, what I suggest is for normal surfing and program downloads. For Instance I have blocked all the Avatars/advts in this page , and it saves some KB for me, and I open almost 6 or seven forums daily two or three times a day. It adds up !With a Home 500 Plan in BSNL, you can easily down load min 1GB in one or two hours DAILY during the NU period. ( Only problem you have to get up early , or keep awake at 2AM !. Users have auto scripts to D/L during these hours of free usage.
@nsaxena,essbebe:
Guys, could you please tell me how to make the Azureus Client autostart torrent downloading at BSNL NL Time ?
And don't worry I will switch on the PC before going to bed but the download should start only after 2am.
@nsaxena,essbebe:
use utorrent, i have both but i am using utorrent,just forward port and utorrent scheduler is very simple,just schedule 2am-8am,for 7days,and download dataone quick usage finder and connect at 2.02 in it,but careful about bsnl server time,i exactly starts my download 2.01am and with in 2 minutes my speed goes to 200KB/s easily,sweet sleep with 4GB download,in azureus u have to download scheduler plug-in,i never use scheduler in azureus because i have no problem in utorrent,essbebe helped me in scheduler topic a lot..
