Need to restart PC when modem loses power
  • Thread starter Thread starter rsen
  • Replies Replies 3
  • Views Views 2,648
rsen
Regular
Bsnl
I have a Huawei MT841 modem, running on windows XP. The problem is whenever there is any kind of voltage fluctuation or loss of power and the modem resets; my PC will not connect to the internet unless I restart my PC. I have an APC UPS but it does not have backup power for modems.Is there any way to prevent the need to restart on any power outage ?
yep the svchost.exe if deleted wont allow u 2 access the internetwell heres sumtin i usually do to minimise the load on the bandwidth (256 kbps:S) open task manager (ctrl+alt+del) there u will see five processes wid the name svchost.exethe first two are safe to kill if we kill the middle one (one wid gr8st mem usage) we wont be able to access the internet..and also wen unning games or video/songs etc maynot function or else we wont hear nytin.. just the video.....bt (70% of times) if its killd b4 connectin to the net...the BSNL is now connected notification wont appear ..but we'll be able to access the net..the last two are not to be deleted ..if deleted they initiate a 60s countdown to shutdown the system(widout logging off)sum othr processes i delte-wuaclt.exe,wdfmgr.exe,jqs.exe(asssociated to java)well u may try these but ..do it at ur own risk..it helps for me
why don't you just connect modem adapter in UPS.I have an APC ups connected lcd monitor,CPU and the modem.take out speaker adapter if you connected.you may not need that when power is out.but you can surf few more minutes when power off like 20+ min .. Try it ..:whistle:
