Hi ![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
This forum has been lot more helpfull to me regarding BSNL broadband problems, how-to guides , Knowledgebase and the hardware details everything.
recently I switched my broadband connection from TATA to BSNL UL900 package. My exchange technician said that I have to buy my router or modem coz they dont have any at this moment to set it up for me. So after reviewing this forum about what modem or router to choose. so after my small research I came to conclusion that to avoid D-Link router and opt fot Netgear (I dunno exactly why i picked netgear over other companies but it seems to be the obvious choice for wired router with basic starting model from them).
So I got this Netgear DG632 Router for Rs.1650 from local store. After setting up with necassary wires and configuration I soon ran into problems. After being setting up necassary configuration like vci vpi numbers username and password with PPPOE as connection type my router wouldn't connect to the server. In router connection status it says dissconected.(even though username&password is coorect). After calling my local exchange technician for help he suggested me to use the router in bridge mode. But I dont want to use my router in bridge mode coz in bridge mode my routers in built firewall is disabled.
My router url is DG632
and the router settings are as mentioned in the BSNL site
So friends I explained in detailed about my problem
My question is how to connect my router using PPPOE to BSNL server. Is there any bug with this router or I have to tweak any setting in router to get this work. I also mentioned this problem to netgear techsupport ..Iam waiting for there reply.
any help would be appreciated
HyderAli
HyderAli
