Nighthawk EAX80 Extender – 8-Stream WiFi 6 Mesh Extender | NETGEAR
Pair the Nighthawk AX8 WiFi 6 extender with your existing router to create a mesh WiFi system that lets you stream, game, and more reliably. Buy now!
www.netgear.com
Check Netgear Deals on: Flipkart | Amazon | Paytm
Introducing the NETGEAR Nighthawk AX8 WiFi 6 Mesh Extender. Create a powerful whole-home mesh WiFi network with the router you already own. Built for the future of WiFi, the Nighthawk AX8 Mesh Extender delivers maximum capacity, speed, and coverage with the next-generation WiFi 6 standard.
Enjoy a better connected home experience and extend faster WiFi to the farthest corners of your home with speeds up to 6Gbps. The Nighthawk AX8 Mesh Extender uses your existing WiFi to create a whole-home mesh network, compatible with previous generation WiFi routers (WiFi 5, WiFi 4).
Upgrade to a new class of mesh WiFi with features like Smart Roaming and One WiFi Name. Extend coverage to the entire home with your existing WiFi name and password and your mobile devices will automatically connect to the best WiFi so you can seamlessly stream from your devices without interruptions as you walk around your house.
With Push Button Setup or the Nighthawk App, you can install your Nighthawk AX8 Mesh Extender in minutes right from your mobile device. Simply download the app, set up your extender on your mobile device, and manage your home network from the palm of your hand. Now you're ready to experience the future of the connected home with the latest generation WiFi 6 technology, only with the Nighthawk AX8 WiFi 6 Mesh Extender.
