NETGEAR Nighthawk X6 Tri-Band WiFi Mesh Extender (EX7700)
  • Views Views 1,585
Check Netgear Deals on: Flipkart | Amazon | Paytm
The Nighthawk App makes it easy to set up your Nighthawk X6 Tri-Band Range Extender right from your mobile device. Simply download the app, plug in your Mesh Extender, and tap on the New Setup option. Connect to your Extender's network and the Nighthawk App will guide you through the few short steps. Once your setup is complete, you can continue to use the Nighthawk App to monitor your network and get more out of your WiFi. Manage connected devices, update firmware, check network status, and so much more!
With the NETGEAR Nighthawk X6 Tri-Band WiFi Mesh Extender, you can have a whole-home mesh WiFi network that's up to 100% faster than traditional dual-band range extenders.
With Nighthawk Mesh WiFi, you can easily create a whole-home WiFi system with your existing router. Extend coverage of your current WiFi with the same WiFi name and password, with One WiFi Name.
