New ACT connection, Speed varying a Lot.
  • Thread starter Thread starter potatoKun
  • Replies Replies 14
  • Views Views 2,018
Are you testing pings on wifi or ethernet?
It could just be wifi signal interference in your house from neighbours. Can you run network analyser app on mobile and laptop? It helps me to get better wifi too when I manually selected less crowded wifi channel.
even tried on lan. only had difference of 2-3ms. 191 got to 188 , 6 got to 4
In that case try different dns servers or compare pings to ip address and not hostnames?
If you are getting pings of 6 to nearby servers then it could be genuine routing issues with ACT so you should try to get your customer care to get the backend team to look into it.
did on both, wifi and ethernet. almost same ping. only a difference of 2-3 ms.
will surely use network analyser now.. it seems like, every small details matters at high speed
ohk, Am on google dns, Will see if anything changes by changing dns
Every fking Isp have routing issue in my area. What should i say to ACT? my friend is getting 15 is COD and i like 30? I don't know if this is enough for them to do anything. And i am not able to think of anything else.
See, my ping is also double of yours. My previous isp- Hathway, showed almost same ping on servers, i am testing now. Maybe routing in my area is messed up or something. TOOO much bad luck. Or every isp is shit here..
and i see your CMD prompt version is higher than mine. maybe i am lacking some crucial update. let's keep fingers crossed LUL o_O and also, what is your locality?
Because Singapore is closer to Hyderabad. Yours pings are just fine.
