Nokia Asha 311 WiFi connectivity problem
i have recently bought TP-Link td 815n modem router & its working fine in pc but when i try to use wifi in my Nokia asha 311 cell detected its wifi & got connected to but page is not opening.. plz tell me step to configure it
yes its configured in pppoe mode when i try to connect it in wep mode errors says mobile data connectiion not available goto setting & turn on mobile data.. but when i turn on data it got connected to gprs & money got deduct from my balance.. same with wpa2_psk mode.. & wen i disable Authentication Type it shows " network cannot be used to access internet. connect anyway?" i also read sumwer in net tht resetting cell will do the trick.. i did that too.. but that also didnt helpwat to do..
on a featurephone, opera would be my recommendation for the web browser too. it works very well on low end devices.
Browser will not run until you switch on mobile data. I face this issue. You can delete all the apns for mobile data, switch on mobile data, it will start using wifi
