Not connecting
  • Thread starter Thread starter gkr
  • Replies Replies 3
  • Views Views 2,995
gkr
BSNL
ERROR 676 BSNL broadband connection does not get connected easily. after the message " connecting through WAN mini port[PPOE]........."it waits for long time and then it shows the message "Error 676:Line is busy"on my ZTE ZXDSL-531B modem DSL indication glows normally.it is so random once in 30 attempts it also gets connected ....please help me out...
There is no problem with your router.This is the problem with BSNL servers.To solve this you will have to switch from Bridged mode to PPPoe mode.
thank you for you prompt replycan u please help me out where should i change that option while creating connection ? can u please guide me
solution found for the problem at last after 5 days i am able to speak to BSNLsolution they have told is:1. Enter modem settings by typing its ip address2. enter the advanced setup3 enter WAN4. in the first column mentioned 0/35, at the last press the "edit" button5. in the new page ensure VPI is 0 and VCI is 35, press "next" button6. in the next page, connection type option select the option "bridging" press next7. press next again8. save and reboot the modemin effect solution is instead of PPOE, bridging option was chosen.since then net is connecting immediately
