hey dude x720 how can u get such a low attenuation rates. mine is 30.5db (down)that means i have far too much noise in my line than urs.what kinda wire are you using....cooper ok... what thickness 9mm or more. i think the copper wire hez on is of ver high quality. but still.....any copper wire cant give a that much low rates. AMAZED and also do ur house have underground telephone wiring which is common now a days and also the lenght of copper wire used from DP (pole) to the (internal house wiring) or modem is very less?????wt kinda wire is that....
Umm, my setup is as follows :The exchange is in the basement of my building. The wiring upto the exchange is optical fibre, then from the exchange to my apartment's pair box (14 floors up) the wiring is copper. Internal wiring is about 2- 3 years old and is again made of copper. I have no idea about the thickness. I guess its due to the lack of joints in the wire (no dp pole and stuff) that I have low attenuation values. All wiring including the ofc is underground.
@aatuifyes frnd...i understand that. dats y was enquiring to him about dis like a FBI Agent. .and mind it - the exchange lives in his building. not him . lucky guy.!
yes thanks for the image. very helpful. so basically my attenuation rates is way much higher. so the according the chart its btween average and poor.it has been always lyk dis 30db (down). even when the line is clear.so in this case what has to be done....???even if i call the line man he will just clear the line. still i would get same attenuation 30db. so wt to do now?shouuld i cut down the ample lenght of wire i have rolled up?or should i ask the line man to give a new high quality copper cable.??
@PiyushHoow old is the wiring at your place ? Both BSNL's external as well as your internal wiring. You might also want to check the attenuation values of those in your neighbourhood. Also, I do not think that cutting down the length of the wire will have a significant impact.
Besides, you cant do much with high attenuation if you live far away from the exchange. My SNR is around 35, Attn is around 27 (normal for 2 km line), still I get an attainable downrate of about 17.5 Mbit/sec.
Check your speed here ( twice ). Your tariff plan ? My Broadband Speed - Broadband Speed Tester
actual speed mattters, rather than attainable rate and Rate shown in modem.
May be your mod mode is now ADSl2 +
@Piyush Chandra
Changing to GDMT gives a stable connection, with reduced sync rate etc.
with some improvement in SNR.
