Panasonic Eluga Ray Max
Nishant
Ulhasnagar, MH
Jetway FTTH, BSNL FTTH
Check Panasonic Eluga Ray Max Deals on: Flipkart | Amazon | Snapdeal | Paytm
Panasonic Eluga Ray Max and Ray X with Arbo smart assistant, fingerprint sensor, 4G VoLTE launched starting at Rs. 8999
Panasonic Eluga Ray Max specifications:
5.2-inch (1920 x 1080 pixels) 2.5D curved glass display with Corning Gorilla Glass 3 protection
Octa-Core Qualcomm Snapdragon 430 ( 4 x 1.2 GHz Cortex A53 + 4 x 1.5 GHz Cortex A53) 64-bit processor with Adreno 505 GPU
4GB LPDDR3 RAM, 32GB / 64GB internal memory, expandable memory up to 128GB with microSD
Android 6.0 (Marshmallow)
Dual SIM
16MP rear camera with LED flash
8MP front-facing camera with LED flash
Fingerprint sensor
3.5mm audio jack, FM Radio
Dimensions: 148 x 73 x 9.5mm; Weight: 165g
4G VoLTE, WiFi 802.11 b/g/n, Bluetooth 4.1, GPS, USB OTG
3000mAh built-in battery with Quick Charge 3.0
