port forwading help
partha_simple
gonna rock this place....
DataOne H500(2.5 GB)
well guys i am a bit confused.
while using bitcomet(to download torrent files) for the first few minutes,abt 2 mins i get to see both remote and local connections.but after that like all the remote connections are eaten away by the local ones and they disappear and all i get is all local connections.
i had started a old thread where i had mentioned a few things which i need to rectify now.
1)i mentioned that i was getting all local connections for only 1 torrent,actually after about 2 mins all torrents become totally local.
2)i had said that inspite of all local connections,i was getting 200+ kBps sppeds in torrents.now that has become a thing of the past.now i'm receiving just 90-100 kBps speeds.the torrents that i am using have lots of seeds and leechers about 400/650.is the drop in speed somehow related to all this?
3)some of you guys had tried to help me and i appreciate that,bt that was of no use to me coz even till now i am not able to access my router's home page using 192.168.1.1 or 192.168.1.1/home or such similar address.mine is a UTStarcom UT300R2U router.
one more thing was....sum1 plz xplain me whats PPPOE mode and Bridge mode????
so guys plz help me to solve these issues.
Local connections indicate connected peers in the torrent swarm, while remote indicates those peers which are there in the swarm but not connected to you.
Now i would recommend that you use utorrent for downloading ateast.
Also i'm supposing that you have already have gone through these links for guidance as they have been repeated quite a few times.
Optimize Your BitTorrent Download Speed | TorrentFreak
and
utorrent,settings,best utorrent settings,optimize utorrent speed,how to make utorrent download faster,tweak utorrent settings,best utorrent port, Triponic
(Thanks to Osiris and Kyrl....who were they i don't know)
Now how are you connected to your router?
USB/LAN?
if on USB try http://192.168.1.2
if on LAN goto http://192.168.1.1
Still not able to access >> hard reset the modem.
UT-300R2U ADSL MODEM MULTIUSER CONFIGURATION
here is a detailed link...Thanks to essbebe for it.
(I wish he was there but its late and he sleeps on time as always, leaving me as night watchman)
Now your final question
what are bridge and PPPOE modes?
Bridge Mode- where the router acts as a bridge between ISP and customer's computer. In bridge mode you have to make a dialup connection for broadband in you computer utilizing the PPPOE of the OS or RASPPPOE - PPP over Ethernet Protocol by Robert Schlabbach. So you basically put the Username and Password on your computer thereby controlling when you want to access the internet.
PPPOE Mode- where the modem/router dials to the ISP and giving a always on internet to the customer's computer. Internet is on when the modem is on.
Now your port forwarding is dependant on whether you are able to access the firmware webpage. If you are not able to access the firmware webpage even by going through the above link as help.
Then try to connect to USB if no success contact customer care and get modem replaced...(if on rental or applicable otherwise)
Now for torrents no one can gaurentee you full speeds unless you are downloading from a private tracker with a known super seeder.
Hopefully i have covered everything..here if not then please try to google a bit before you return with more.
I'm sure essbebe will have more to add when he comes on in the morning unless he is celebrating holi.......
Happy Downloading...forwarding....troubleshooting..... and yes HAPPY HOLI
:D
