PPPoE on Router - Connection Timeout errors!
Ashwin, could you tell me the DNS server details you used?
Just got an HNS connection in Thane. Works fine on a direct conection to my laptop. Trying to set it up on my TP-Link router.
I reset the router, and entered the user-name, password, Service name (HNSPPPOE).
Entered setting as Dynamic IP, and it even got an IP.
Under Connection mode, i set it as Connect Automatically, yet theres a panel that juts says "Connecting....." when i click on the Connect button.
I think its because the DNS server ips are blank. :s
Any suggestions?
DNS for HNS is 123.108.224.6 and 123.108.225.6.
Normally when the router just says "connecting" it means the service name is wrong - check lowercase/uppercase etc.
Is your account a PPPoE account - as in, do you normally "dial up" to access the Internet or does it just work when you plug in the cable and then it comes up with the login page? If you use the login page, you'll need to get HNS or your cable operator to reset the binding (and change to PPPoE on the router).
Can you ping to 123.108.224.10 when you're connected via the router?
Thanks for your reply MGCarley! Doesnt work with the DNS ips either :(
Here are screenshots of my router page
http://imageshack.us/photo/my-images/716/tplink1.jpg/
http://imageshack.us/photo/my-images/13/tplink2n.jpg/
My accoutn is set up as PPPoE, i.e., i dial-up from my lappie.
When i'm on my router, i'm not able to ping the mentioned ip.
Thanks for your reply MG! The DNS server ips make no difference :(
http://imageshack.us/photo/my-images/217/tplink1.jpg/
Tried with different combinations of the Service Name (should it be entered as the AC name as well?)
My acc is a PPPOE acc, i.., i have to "dial-up" when the wire is connected to my laptop.
Am unable to ping 123.108.224.10 when connected via the router.
Thanks for your reply MG! The DNS server ips make no difference :(Tried with different combinations of the Service Name (should it be entered as the AC name as well?)My acc is a PPPOE acc, i.., i have to "dial-up" when the wire is connected to my laptop.Am unable to ping 123.108.224.10 when connected via the router.(tried posting a screenie, but it says my posts have to be moderated :-/ )
You *probably* need to get the MAC binding reset (this is usually there by default) - call your cable operator or HNS directly tomorrow and just tell them you've got a new router and the MAC ID is aa:aa:aa:aa:aa:aa (whatever is written on the router).
Thanks MG! Have asked them to reset the MAC binding.Will get home and check it up tonight.P.S. Any DC++ hubs? :s
Awesome. I'm connected!In case anyone else is facing the same problem as i did, after you've got them to reset the MAC address and entered your details on your router page, WAIT for like 10-15 mins. (DNS server ips are not necessary)Thanks again for your help MG :)
Hi guys, I got Honesty net service few days back, but I am facing issue while configuring Netgear 150 router. I am using Netgear genie to configure the same. After filling all details n clicking on connect, it shows " Incorrect usename or password". I am using the same id and modem password to connect through LAN and its working fine. I am not sure what exact issue is? DO I need to add some address to my username. Suppose my username is " Amit", Do I need to enter "Amit @xyz" or Amit alone is sufficient".
Settings are:
Connection Mode: Always On
Domain Name: Get Automatically,
Router Mac Address: Tried default and the one mentioned on Router
Please suggest..
