problem wimax connection
abhijeet_iim
HiMy bsnl wimax connection has stopped working on my laptop...IT WORKS ON MY FREINDS' LAPTOPOn my laptop (windows 7), in the taskbar, it shows connected and everything seems fine but i cant access any sites or download anythingDoes this have to do with a bluetooth device i installed a few days back or some other issue...plz guide me
i did ipconfig /all and this is the replyWindows IP Configuration Host Name . . . . . . . . . . . . : EMPERORS-EMPIRE Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : NoWireless LAN adapter Wireless Network Connection 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter Physical Address. . . . . . . . . : C2-17-FE-9E-88-22 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : YesWireless LAN adapter Wireless Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Atheros AR5B93 Wireless Network Adapter Physical Address. . . . . . . . . : C4-17-FE-9E-88-22 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : YesEthernet adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Broadcom Netlink (TM) Gigabit Ethernet Physical Address. . . . . . . . . : 20-6A-8A-62-33-DD DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::45a9:d5c7:d471:750%10(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.51(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : 10 February 2013 20:03:02 Lease Expires . . . . . . . . . . : 10 February 2013 21:03:01 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DHCPv6 IAID . . . . . . . . . . . : 169896586 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-6B-8B-F3-20-6A-8A-62-33-DD DNS Servers . . . . . . . . . . . : 192.168.1.1 NetBIOS over Tcpip. . . . . . . . : EnabledTunnel adapter isatap.{079E895E-A34A-44CA-AB30-B5385D4D0B79}: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : YesTunnel adapter 6TO4 Adapter: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft 6to4 Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : YesTunnel adapter Reusable Microsoft 6To4 Adapter: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft 6to4 Adapter #2 Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : YesTunnel adapter Teredo Tunneling Pseudo-Interface: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2001:0:9d38:953c:2463:119b:8a0c:4ece(Preferred) Link-local IPv6 Address . . . . . : fe80::2463:119b:8a0c:4ece%15(Preferred) Default Gateway . . . . . . . . . : :: NetBIOS over Tcpip. . . . . . . . : DisabledTunnel adapter isatap.{3B7EE1CC-A539-4694-9B23-6D97C1B5FB80}: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3 Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : YesTunnel adapter isatap.{FFC5FCDF-4747-4712-BF6B-9F99DAAC4582}: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4 Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
i tried some pinging and here are the results
C:\Windows\system32>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 timeping Google
Pinging Google [173.194.38.152] with 32 bytes of data:
Reply from 173.194.38.152: bytes=32 time=178ms TTL=52
Reply from 173.194.38.152: bytes=32 time=182ms TTL=52
Reply from 173.194.38.152: bytes=32 time=243ms TTL=52
Request timed out.
Ping statistics for 173.194.38.152:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 178ms, Maximum = 243ms, Average = 201ms
i uninstalled both the wired and wireless adapters and reinstalled on system reboot but still net is not working...the network icon shows my laptop is connected but i cant open any sites, cant access my modem through 192.168.1.1 but when i use utorrent i can connect to seeds/leeches but speed is below 1 kbps...i have set my ip address as auto set and my connection works perfectly fine on my friend's laptop...kindly advise
Request timed out.
