Problem with DLink DIR-803
Hyderabad
Hi
Two days back after reaching home I was not able to access internet. I thought there might be some issue with my ISP so I waited for some time and called them. They said everything was fine from their side. So, I connected the cable directly & it worked. Then i realized that my router has the problem and done a reset using reset button and configured it to my ISP's static IP. Still it didn't worked. The three lights(Power,Internet,WiFI) are on as usual. I couldn't figure out what is the problem. I mailed to DDS.Support@dlink.co.in explaining the issue and about warranty(has 2 more years of warranty) but didn't got any reply from them. Can you guys tell me what should I do.
I'm from Hyderabad
