problem with multi-user
  • Thread starter Thread starter fizspace
  • Replies Replies 8
  • Views Views 1,748
fizspace
BSNL
I have just made multi-user settings in my siemens modem to use with laptop wifi. The wifi is working perfectly but when i don't use the wifi (when its idle), the laptop keeps on downloading data, i don't know where but it keeps on downloading. I have broadband usage meter installed which shows data being downloaded continuously.I checked it the wifi using it with my friend's laptop but the condition is same.
Have you used a security key ?
Your local Broadband meter cannot show download/s if your WIFI is used by someone else.
Reference : similar Hardware board, modem menu pages.
https://broadband.forum/bsnl-broadband/50052-utstar-wa3002-g4-vade-mecum-quick-reference/#post331246
Not clear . refer or Post SS of relevant
security key/router settings.
or
Check in Wireless Settings page
In box on top listing your WLAN card
click configure
Advanced;
Check selected option SSID or anything else
2..
You can also enter the MAC address of your laptop
3
For reference
see the links if any available for WIFI settings
Thanks Vivek, changing the wpa group rekey interval to 0 worked !Now, the wifi is stable.Thanks all for the help. :urock:
