Problems with Dual Broadband Lines
  • Thread starter Thread starter vikikivi
  • Replies Replies 16
  • Views Views 3,478
vikikivi
Regular
DataOne
Hi, I recently got a SIFY pack of NU 256kbps . I hv two ethernet cards connected to my system. One for DATAONE and the other for SIFY. Now, when i keep both the LAN connections enabled, the dataone dialer gives me some error. It isnt establishin the connxn. So, during day times , i disable the SIFY LAN and then connect to DATAONE. I do the reverse after 10 PM to connect to SIFY. Can any1 give me a solution for this ?? I dont want this enabling-disablin business coz sometimes i forget to do this and my dad keeps trying and trying and gets fed up with the pc and ultimately I BECOME THE TARGET. :P
i want to fuse 2 lines of airtel coming at my place. someone help me on that too :D i got a linux server machine here if that woudl help :D if someone can come here and fix it that would be lovely. i would order pizza for the dude who manages to do it ;)
i think there is no solution..i have incable which requires me to login using cyberoam client...so whenever i need to login i have to disable my DSLs..else it doesn't work....Sushubh..did you try wingate? it works very well for http downloads..for newsgroups..and websurfing (somewat)..though it doesnt work for irc..There's a thread on the mtnl forum which contains a fusion.txt or something telling how to do that.....I'm currently using 2DSL nu's at night....works flawless..though wingate is just 1 month licensing..I had to reformat my comp. just so i could get it to work again..couldnt find a way around it :P
does it work as a proxy? coz i need transparent proxy for some softwares we use at work. i actually bought a linux machine to do this. their are certain packages which bridge enabling loadsharing. the linux guy at my place could not do that :(
