Querry regarding ONU(V2801SG) and secondary router and help me comprehending error logs.
  • Thread starter Thread starter ransomware
  • Views Views 1,007
DELHI
mylink
Today, I've tried to configure my ONU into bridge mode by deleting PPP settings and also disabling NAT and DHCPV4/V6, prior it's working in route mode. After doing such settings my internet didn't work, I've also cloned WAN M.A.C. of ONU's, still didn't work. Also, I'm providing my wifi-router's log which I assumed to handle my PPP on instead ONU:
Code:
2024-08-17 20:34:41 led-controller[774]: <6> 288051 Start to run WAN1_OFF
2024-08-17 20:34:41 led-controller[774]: <6> 288051 Start to run WAN0_OFF
2024-08-17 20:34:41 led-controller[774]: <6> 288051 Start to run LAN_ON
2024-08-17 20:32:34 ppp[16047]: <6> 261021 pppoe send PADI Host-Uniq(3eaf)
2024-08-17 20:32:34 ppp[16047]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:32:32 nat[16068]: <6> 211501 Initialization succeeded
2024-08-17 20:32:31 led-controller[774]: <6> 288051 Start to run WAN1_OFF
2024-08-17 20:32:31 led-controller[774]: <6> 288051 Start to run WAN0_OFF
2024-08-17 20:32:31 led-controller[774]: <6> 288051 Start to run LAN_OFF
2024-08-17 20:32:31 nat[16068]: <6> 211501 Initialization succeeded
2024-08-17 20:32:29 ppp[16047]: <6> 261021 pppoe send PADI Host-Uniq(3eaf)
2024-08-17 20:32:29 ppp[16047]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:32:27 led-controller[774]: <6> 288051 Start to run WAN1_OFF
2024-08-17 20:32:27 led-controller[774]: <6> 288051 Start to run WAN0_ON
2024-08-17 20:32:27 led-controller[774]: <6> 288051 Start to run LAN_OFF
2024-08-17 20:32:19 ppp[15702]: <6> 261021 pppoe send PADI Host-Uniq(3d56)
2024-08-17 20:32:19 ppp[15702]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:32:09 ppp[15702]: <6> 261021 pppoe send PADI Host-Uniq(3d56)
2024-08-17 20:32:09 ppp[15702]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:32:04 ppp[15702]: <6> 261021 pppoe send PADI Host-Uniq(3d56)
2024-08-17 20:32:04 ppp[15702]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:31:53 ppp[14071]: <6> 261021 pppoe send PADI Host-Uniq(36f7)
2024-08-17 20:31:53 ppp[14071]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:31:46 nat[14569]: <6> 211501 Initialization succeeded
2024-08-17 20:31:45 remote-management[14739]: <6> 282505 Service stop
2024-08-17 20:31:45 nat[14569]: <6> 211501 Initialization succeeded
2024-08-17 20:31:43 ppp[14071]: <6> 261021 pppoe send PADI Host-Uniq(36f7)
2024-08-17 20:31:43 ppp[14071]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:31:39 nat[13889]: <6> 211501 Initialization succeeded
2024-08-17 20:31:38 ppp[14071]: <6> 261021 pppoe send PADI Host-Uniq(36f7)
2024-08-17 20:31:38 ppp[14071]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:31:38 network[13842]: <6> 290003 Connect interface internet
2024-08-17 20:31:38 network[13842]: <6> 290003 Connect interface wan
2024-08-17 20:31:37 network[13842]: <6> 290004 Disconnect interface wan
2024-08-17 20:31:35 network[13842]: <6> 290004 Disconnect interface internet
2024-08-17 20:31:35 network[13842]: <6> 290102 Set PPPoE, username is xxxxxx
2024-08-17 20:31:35 network[13842]: <6> 290100 Set WAN protocol to pppoe, operation is connect
2024-08-17 20:31:29 ppp[12749]: <6> 261021 pppoe send PADI Host-Uniq(31cd)
2024-08-17 20:31:29 ppp[12749]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:31:19 ppp[12749]: <6> 261021 pppoe send PADI Host-Uniq(31cd)
2024-08-17 20:31:19 ppp[12749]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:31:16 remote-management[13044]: <6> 282505 Service stop
2024-08-17 20:31:15 nat[12712]: <6> 211501 Initialization succeeded
2024-08-17 20:31:14 led-controller[774]: <6> 288051 Start to run WAN1_OFF
2024-08-17 20:31:14 led-controller[774]: <6> 288051 Start to run WAN0_ON
2024-08-17 20:31:14 led-controller[774]: <6> 288051 Start to run LAN_ON
2024-08-17 20:31:14 ppp[12749]: <6> 261021 pppoe send PADI Host-Uniq(31cd)
2024-08-17 20:31:14 ppp[12749]: <6> 261026 pppoe send PADT due to(resending PADI)
2024-08-17 20:31:03 nat[12069]: <6> 211501 Initialization succeeded
2024-08-17 20:31:02 nat[12069]: <6> 211501 Initialization succeeded
2024-08-17 20:30:58 nat[11413]: <6> 211501 Initialization succeeded
2024-08-17 20:30:57 nat[11413]: <6> 211501 Initialization succeeded
2024-08-17 20:30:56 traffic-stats[6766]: <6> 269004 stats reset
2024-08-17 20:30:56 network[11360]: <6> 290005 Reload config
2024-08-17 20:30:55 network[11360]: <6> 290004 Disconnect interface wan
2024-08-17 20:30:53 network[11360]: <6> 290004 Disconnect interface internet
2024-08-17 20:30:52 network[11360]: <6> 290102 Set PPPoE, username is xxxxxx
2024-08-17 20:30:52 network[11360]: <6> 290100 Set WAN protocol to pppoe, operation is write
2024-08-17 20:30:38 remote-management[10197]: <6> 282505 Service stop
2024-08-17 20:30:38 nat[9824]: <6> 211501 Initialization succeeded
2024-08-17 20:30:37 nat[9824]: <6> 211501 Initialization succeeded
2024-08-17 20:30:34 imb[9729]: <6> 218507 Daemon connection succeeded
2024-08-17 20:30:34 imb[9729]: <6> 218012 ARP Binding disabled
2024-08-17 20:30:34 imb[9729]: <6> 218506 Config interface initialization succeeded
2024-08-17 20:30:34 imb[9729]: <6> 218501 Initialization succeeded
2024-08-17 20:30:28 upnp[9165]: <6> 217504 Service start
2024-08-17 20:30:28 upnp[9165]: <6> 217505 Service stop
2024-08-17 20:30:27 led-controller[774]: <6> 288051 Start to run WAN1_OFF
2024-08-17 20:30:27 led-controller[774]: <6> 288051 Start to run WAN0_OFF
2024-08-17 20:30:27 led-controller[774]: <6> 288051 Start to run LAN_ON
2024-08-17 20:30:25 nat[8353]: <6> 211501 Initialization succeeded
2024-08-17 20:30:24 nat[8353]: <6> 211501 Initialization succeeded
2024-08-17 20:30:24 remote-management[8654]: <6> 282505 Service stop
2024-08-17 20:30:23 traffic-stats[6766]: <6> 269004 stats reset
2024-08-17 20:30:23 network[7914]: <6> 290005 Reload config
2024-08-17 20:30:23 led-controller[774]: <6> 288051 Start to run WAN1_OFF
2024-08-17 20:30:23 led-controller[774]: <6> 288051 Start to run WAN0_OFF
2024-08-17 20:30:22 led-controller[774]: <6> 288051 Start to run LAN_OFF
2024-08-17 20:30:22 traffic-stats[6766]: <6> 269004 stats reset
2024-08-17 20:30:22 network[7914]: <6> 290004 Disconnect interface wan
2024-08-17 20:30:20 network[7914]: <6> 290004 Disconnect interface internet
2024-08-17 20:30:20 nat[7873]: <6> 211501 Initialization succeeded
2024-08-17 20:30:19 network[7914]: <6> 290010 Call ddns to change interfaces
2024-08-17 20:30:19 traffic-stats[6766]: <6> 269002 stats on
2024-08-17 20:30:19 traffic-stats[6766]: <6> 269003 stats off
2024-08-17 20:30:19 network[7914]: <6> 290102 Set PPPoE, username is xxxxxx
2024-08-17 20:30:19 network[7914]: <6> 290100 Set WAN protocol to pppoe, operation is write
2024-08-17 20:30:18 network[7814]: <5> 290250 Restart interfaces
2024-08-17 20:30:17 network[7814]: <6> 290106 Set MAC address to FF:FF:FF:FF:FF:FF
2024-08-17 20:30:17 network[7814]: <6> 290150 Set mac clone
Please help me with associated Logs of my router (NOT ONU) sorry! for masking info, don't mind.
