I just got reliance broadband connection installed this monday.
PLAN:- thunder 699(ADSL)
And from day one my upload speed is slow, vary in between 170-250 kbps(kilobits)
here's my modem status
Downstream Upstream SNR Margin:3.8 4.5 db Line Attenuation:19.6 16.0 db Data Rate:4095 229 kbps Max Rate:5268 272 kbps POWER:19.3 12.0 dbm CRC:7 0
So, what could be the reason for slow upstream data rate.Am i being synchronised at wrong upstream data rate OR there is some issue with my line.Yesturday i called the lineman he said line quality is acceptable and this issue maybe from backend.
Max upstream data rate i have seen so far is 312 kbps that too only once.
