Not possible (as far as I know). Using the same modem with BSNL. If your laptop / desktop has Windows Home Premium or above you can install " Connectify " and make it a WiFi hot spot. You can choose your desktop if it has a WiFi adapter ( USB one costs around Rs. 900).
Now i am shifting my connection to Reliance Broad Band
They Say that their BB does not support wifi Connection router
Can I use MY BSNL WA3002G4 Modem TO connect Both My laptop and desktop using the same connection or NOT !!
Kindly Reply Soon!!
if u are using a metro ethernet connection u can use your bsnl wifi router to make a single user wifi network for reliance but u cannot make a multiuser network( wifi and wireline )// only single user can be done because as far as i know bsnl routers neither support mac cloning nor pppoe over lan...
but it supports pppoe over wan so if you are a reliance user with adsl media then simply creating a pppoe connection u can share it over wifi and wireline both...
Thanks For ur replyHere IT is ADSL Line ConnectionAnd My Pc Is not Wifi Enabled & Laptop olnly supportsSo that i ask That can i Use THe Singe BB connection for Both of them SimultaneouslyDoes My BSNL WA3002g4 Will Be abled to configured In PPoE with My Reliance Broad Band or it need some tweeks Plz Make Sure And Reply
