Same BSNL Reconnecting Problem
  • Thread starter Thread starter maxima89
  • Replies Replies 4
  • Views Views 2,803
maxima89
BSNL
I have tried searching the forums but haven't seen a good solution to this problem other than contacting the ISP staff.I am having BSNL net connection for past 2.5 years now and lately I am facing this problem of net reconnecting within 15-25 minutes or so.I used to have a UT200R2U modem earlier but it sadly had a technical failure(some hardware problem) which the BSNL staff said was irreplaceable/irrepairable. So i had no other option but to buy a new modem and i bought the new Nokia Siemens C2110 modem which is supposed to be a dual line supporting modem.I had tried configuring it to be manually connectible but it always gave an Error:678(server not responding) so I had to switch to automatically connect/always on option where my username/password were stored in the modem.The net works fine but the only problem persists is of network reconnection.It becomes quite frequent in the morning but at the evening/night it works perfectly(i.e. no reconnection).Some points I would like to clarify:1. This is my 3rd modem change in almost a month or so.2. My Local SNR Margin is : 14.5 dB3. My Local Line Attn is : 30.0 dB However I have noticed while i directly connect the phone line to modem these reading are observed.But when i connect line from splitter the reading change significantly......SNT Margin Increases to about 29 and Line Attn decreases to about 20-25.4. I do not have any other parallel lines installed at my place.I would kindly request the more senior and knowledgeable members of the forums to kindly direct my problem as I have tried to contact the BSNL office so many times and had to personally visit them about 4-6 times and after that they had come to repair my modem/address to my modem trouble. The staff seems to me as non functioning unit and are not much bothered about addressing to their customers grievance quickly. Already due the modem trouble I had lost almost 1 month of my net usage time(i.e. my net was not functioning for almost a month) and after giving a lot of reasons to my net problem they finally said that my modem was at fault.
splitter ==LANport===>>rj11==>> modem. correct.
For ref:
C2110 ADSL MODEM (Type-A) MENU
Para two:
In computer TCP/IP properties Obtain Ip address automatically.
DNS use 208.67.220.220. and 208.67. 222 .222
In modem try Mod GDMT
Give feedback .
Post ipconfig/all
Update 1240 : The net works fine
After reading again your post : give details of your system. How many computers are in the network ?
When updated etc ? How is the powerline variations in your area/house ?
As I have already mentioned, I am using the C2110 modem and am already using the always on option with PPPoE with LLC/SNAP(don't know what this is).
And with reply to your ipconfig command:
I hope this helps.
EDIT: I am using:
Windows XP V 2002 SP2
Intel Dual Core 2140 @1.61 GHz
1.6 Ghz with 512 Mb RAM
Edit 2:
There are no other computers connected to my network.
My PC/Modem and connected to my UPS backup which in turn is connected to my Invertor backup for double protection. There isn't any power fluctuation and power is consistent here leaving a 4 hour daily power cut routine aside.
In computer TCP/IP properties Obtain IP address automatically.
enter open dns given above.
Does the modem page look like this ?
http://img138.imageshack.us/img138/4396/nokiasiemensc21102mq7.jpg
I have done what you have advised me to do,i.e. I have made the DNS as the open DNS using the given address. Also thanks for giving me the BSNL page address and now I have upgraded the firmware of my modem and Yes the modem page looks almost the same but does not have the 'Security' tab in it.Using the guide at BSNL site page,I have made a PPPoE connection using the bridged mode which can be connected manually.Lets wait to see whether the problem has been solved or not.Thanks for your help,I will post the updates asap.
