well, as the title says....Is anyone aware of a script or a tool or some mechanism of some sort which can automatically disconnect and then reconnect to obtain a new ip address at 2am???? Other then me doing it myself that is
problem solved.....just wrote a small java prog to run telnet and reboot the router at 2am and 8am.P.S : I did search the forums, but none of the solutions suited my requirement. Besides, my way is easier.....-peace:thumb:
@rachit_1804
Did you try the application given in Post 3.? ( Now No 1 in forums!) http a program years back.
@milano
less than 16MB download it here. Download Java Runtime Environment 1.6.0.12 - FileHippo.com
But where is the script ?wrote a small java prog to run telnet ...
Send PM to @srinag, if he is willing to share.
