I bought C6 v4.8 from Amazon AC1200 Wireless MU-MIMO Gigabit Router and would probably need a extender mesh setup because of multiple obstacles blocking wifi.
This router is compatible with 'easy mesh' tech which is kinda a new universal standard for mesh tech. More about it TP-Link EasyMesh Devices
One issue is not all range extenders support both wired and wireless backhaul, only RE315 does and is not available currently.
Other option is RE205 Amazon.in which has a ethernet port but limited to 10/100Mbps and only supports wireless backup for easy mesh setup.
So instead of range extender I can get another C6 v4+ or C64 router AC1200 Wireless MU-MIMO WiFi Router Both support easymesh tech and should work with wired backhaul, atleast thats what i understood from TP-Link site. But both routers support wireless easy mesh setup.
So to summarize:
RE ethernet port is not gigabit, limited usage as extender, wireless backhaul only for mesh, 2 antennas.
Router has gigabit ports, multiple uses as router & extender, both wired and wireless support for mesh, 4 antennas. More lan ports. Costs 500-700 extra.
P.S. I have not tested the lan cables if they all connect to each other but its present. Worst case i have to use wireless for mesh.
Edit: How to Build an Ethernet Backhaul Using Two EasyMesh Routers | TP-Link
So to summarize:
