raviaswath
Hi, I recently started using WAG200 Linksys wireless modem for my BSNL broadband connection. I also have been using a wireless handset Panasonic KX-2G2360 for taking voice calls. I have used a splitter to split the incoming phone copper cable to the Linksys modem and the wireless handset. The problem I am facing I that whenever the Linksys modem is switched on, there is a severe "ssssssss" noise whenever I use the wireless handset. This noise vanishes when I switch off the modem. I tried moving the Panasonic base station away from the modem to see if it can solve the problem; but it does not help. What could be the problem? Are the 2 frequencies of the modem and the wireless handset clashing? (seems unlikely). Any pointers that will help solve this problem is welcome. Thanks for your time. Ravi.
