goat0brain0balls0
in ism 802.11 spectrum? channel 1,6,11 never cause interference. they are perfectly shifted by 22 mhz, choose either of the channels 1,6,11. if you got a japanese made/make? you are damn darn lucky. you got channel 14 also free from interference. try altering the channels and see which one is not interfering with the corresponding frequencies. if phone uses 6 channel then change the wireless channel to 11 or 1 and vice versa. if you can change the phone's channel frequency via control/config mode? do it. and i can lay a bet 1,6,11 (and 14 if available) will never interfere in transmission. hope it helps.
