coolbuddyin
Regular
Just as you said and done via usb flash drive but Instead of 192.168.0.1 of Lan ip address of desktop i used '192.168.1.2' (because if i change it net wont connect) .
As im using Dataone in PppoE mode so I Changed the value in internet Protocol (TCP/IP ) of LAN in Desktop and Wireless network setting in Laptop is that correct?
Also i Didnt get the first part btw where you change settings in Router. how and what value should i enter in mine D-Link glb 502t router.
Btw as i connected now shouldn't atleast the file sharing work now properly? is there anyway where i can properly check did i connected properly, some ping values etc?
both ur comp working on xp right?
file sharing to work make sure ur laptop.,desktop., and router three same ip range
192.168.1.* in your case
use ips from 192.168.1.3 instead of 192.168.1.2 is used for usb interface of dataone modem
and also check that work group name in both computers same,.u can check it in my computer > properties > computer name
