My connection is NIB 2 now so can i ask bsnl to shift me to NIB 1...as i have NIB 1 unlimited id and yeah multiple idit used to work for me when i was in NIB 1 so do they allow you to shift bak to NIB 1???
NIB stands for national internet backbone and u cant change from NIB1 to NIB2 and you cant use your other user id password because your port has been changed.basically Huawei port (old ports) users can use any user id .as this are getting older they are replaced by the bsnl exchange by mp port and siemens port(name of the manufacturer) .this new ports replaced at the exchanged comes with port binding and are more secure so u cant use any other user id which is assigned to your other telephone connection.this ports combined together and are connected to DSLAM (digital subscriber line access multiplexer) AND THIS ARE CONNECTED TO NIB (THAT IS NIB1 OR NIB2 )HOPE U UNDRERSTAND WHAT I JUST HAVE TYPED :dance:
so if I change DSLAM settings I can make it?? ALso the new routers are manually altered to port bind or are done automatically by server??? How can I check thi sthing in my rouer???
so if I change DSLAM settings I can make it??:hysterical:
