Sify Client does not work with Win98
  • Thread starter Thread starter popcorn
  • Replies Replies 25
  • Views Views 5,212
Yes using with super sify...... also tell me which file stays in the memory when i do the crtl alt del button in winxp? I shall now use win98 gold with this combination...shall it work....bcz my aim is to use win98 with sify.
cancer... i dont see anything like that in applications tab. in processes tab i can see some 2 to 3 new exec files so which one is yr file? meaning the excat name of exe file?
yes it worked.... But that Monitor word is a bit misleading... may be u can replace it by "minimize to system tray" ... :) also if u can also use those bells below blinking in colours for network flow in yr next version? ! ;)
When you place your mouse cursor over the "Monitor" button., it will say wot you suggested in your post :)BTW, those are not bells but characters as you see on msn messenger.
oops Sorry i did not see those msn characters..... But that monitor word comes when u first install it. A user shall not know that there is a mouse over and most likely that user shall click exit button. So as a first time user may miss the monitor button and close the software and shall decide not to use it as it did not work. So I just gave u the suggestion. Also once user says I want to update every 1 hour the Monitor button changes to Tray so u may think here too .. :) Monito and Tray are a bit misleading... I suggest to use just tray at both places.....
