Smart Air on Amazon India
QT3 Portable Air Purifier – Smart Air
Truly lightweight HEPA QT3 portable air purifier. Bring clean air with you wherever. Experience clean air around you no matter where in the world you go.
smartairfilters.com
So, it is basically a toy fan with hepa filter with an optional battery version that you can run without power supply.
Good thing is that it uses USB-C. This makes it a good option for your car. Battery life range from 2 hour to 4 hour depending upon fan speed.
India is not getting this yet.
If and when this comes to India, I would probably order a unit to use in my car lol. Or maybe as a desktop fan for summers. Should be priced under Rs. 2000 based on the pricing.
