Google search " generic host win 32 error"
Fix Generic Host For Win32 Process Error
Here are 4 new solutions to the Generic Host For Win32 Error in
Windows:
Solution# 1:
1. Hop to ‘Run’ and open ‘Regedit’
2. Navigate to:
HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Services > Browser > Parameters
3. Find the Key
and set
Data: False
4. Restart Your PC
Solution# 2:
1. Go to ‘Run’ and open ‘cmd’
2. Type ‘netsh’ in command console then press enter
3. Then type ‘winsock’ and press enter and then type reset
4. Restart Your PC
Solution# 3:
Get the LspFix and follow the steps as directed
Solution# 4:
Get the
Microsoft Update Patch and apply it
Hope one of these solutions will definitely help you rectify the erorr
Moreover you can always see my old guaranteed post about Fixing Generic Host Error
Comments
Comments on this post
Nirmal on Apr 28, 2007 (Reply)
Hi DJ,
Thanks .....
seems the link is not available quoted in above blog.
