Some problems after password change.Help!
  • Thread starter Thread starter bsnluser89
  • Replies Replies 7
  • Views Views 1,653
bsnluser89
Dataone
I am a new bsnl broadband home500C user.I have changed my password at dataone usage portal.( http://bbservice.bsnl.in/ ) for security reasons.
But now the portal usage is not updating. I mean it is showing old usage details only. What do I do?
:whistle::whistle::whistle::whistle::whistle:
Can you clear your internet history/private data/cookies and try ?Since you are able to login to the webpage, i dont think there is any problem with username/password... may be a temporary issue.. i was not able to login at all after changing the password. we are not supposed to change the password.. that is the message i got from them !!
very true..one of my friends did the same, he changed his password in the portal and wasnt able to connect to the internet after that.. he also changed it in his modem.. still he had some problems....it was resolved after 3 weeks..
there is no problem in changing password.only make sure that you do it one at a time.for safety change portal password first.after changing portal ID password(don't change internet password yet until you confirmed that changed portal password is working fine by login 4-5 times by using changed password) do not disconnect but just logoff.then try login.in my case i got an error & i tried with default password password & it opens.i then again changed the password to same new one as before.this time after logoff & again login my changed password worked.also make sure that this process is not interrupted by power/connection failure so try this at a time when bsnl portal is working smoothly & it is opening as soon as you enter the URL(e.g today bsnl portal is not opening so its not a good idea to change password today if you finally be able to open portal page after many tries).
I also can't access bsnl port today. What's the matter? (I am new to bsnl)
Is this a usual thing:confused::confused::confused:
was down and not working now too !
