Nikhil Soni
- Messages
- 90
- Location
- NA
Hi,
Coming directly to the point ..
I changed my plan from 750ULD-Combo to 900ULD-combo (4mbps upto 8Gb 512 kbps post FUP)
On 29 my plant was changed and it was also changed in the Portal
I received the call from BSNL that plan is changed and you will be getting speed..
But I am getting 1.7mbps download speed and not 4mbps.. i.e. Download speed is 210KB/s and not ~500KB/s
I called BSNL and reported the problem but they said that u will be getting speed from 1st of feb ..
I said "Ok "
but according to me , I am not getting speed is due to the fact that my line is capped @ 2044kbps as seed in the stats of modem ..
because if I was getting 512 kbps as FUP then my speed should not be popped at 210 KB/s (because previously I was getting 512 kbps since I already finished 6gb )
It simply means that my plan is changed but speed is slow due to line ..(*may be )
I again called BSNL and reported the problem and received the same response (You willl get speed after 1st)
But the point is if my line is capped than how the f**k I will get speed :/
Here is the stats :
So guys help me what should I do ?
Where to complaint regarding this ..
I said "Ok "
Here is the stats :
Code:
Device InfoBoard ID: 96338W-20P2Software Version: 3.08.02.IB.02.01_1206_030308Bootloader (CFE) Version: 1.0.37-10.1Firmware Version: DNA-A211-I-0001.01Hardware Version: DNA-A211-I 2.6Model Name: DNA-A211-IWireless Driver Version: 3.131.35.6.cpe2.0a.sThis information reflects the current status of your DSL connection.Line Rate - Upstream (Kbps): 943[B]Line Rate - Downstream (Kbps): 2044[/B] -< Notice 2044 kbps LAN IP Address: 192.168.1.1Default Gateway: 117.212.224.1Primary DNS Server: 218.248.255.212Secondary DNS Server: 218.248.241.2
Code:
SNR Margin (dB): 19.9 4.6 [I]SNR and attenuation values are acceptable and attainable rate is also 8700kbps ( but the actual rate is 2044 kbps) [/I]Attenuation (dB): 17.0 9.5 Output Power (dBm): 12.9 0.0 Attainable Rate (Kbps): 8700 948 Rate (Kbps): [B]2044[/B] 943
