1. I am currently into home plan 750(unlimited)
2. Download speed as per dataone.in is 75.19 kb/s(bandwith 601.50kbps)
This is strange since in
Home UL750 you should only get maximum of 32 KiloBytes/seconds aka 256 kilobits/seconds. Why are you getting higher figures in speedtest?
Anyway, 20 kiloBytes/second is still on the lower side for your plan.
So do this:
[*] Go to
ADSL configuration (192.168.x.x) and check your firewall settings. Have you turned on the DOS or DDOS protection? Turn it off since a flood of p2p packets can confuse the firewall into thinking you are having a DOS attack. Save and Reboot. Test.
[*] Disable any software firewalls and reboot. Test to see if speed improved.
[*] You seem to be using Bridge mode (dialer) to connect to Dataone. Try and switch to PPPoE mode connection (search this forum on how) and then see if it makes any difference to speed.
[*] How many torrents are you downloading simultaneously? Try to get one or two world famous torrents from TPB with 5 or more seeders at 100%. See if that improves the speed. pause all other torrents when conducting this test, and also see that upload rate is reasonable.
[/list]
What kind of speed do you get from link-removed, megadownload, depositfile? What kind of speed do you get when you download patches from
Microsoft website? Are only torrents slow or other downloads also slow?
how do i open
DNS Server if you could please help
DNS wont affect download speed from torrents or throughput, but it is a good idea to use openDNS since BSNL sucks.
[*]Go to 192.168.1.1 or wherever your ADSL modem is located.
[*]Locate the DNS tab.
[*]Type in the addresses mentioned above.
[*]Save and Reboot the ADSL modem.
[/list]
In my modem, it is configured
like this.
