Storage Options: Scroll Extreme - Scroll Engage
  • Replies Replies 1
  • Views Views 1,169
The 8-inch Scroll Engage, at £130 ($200), slots between the existing 7-inch Excel and 9.7-inch Extreme models, with the same Cortex A8 1.2GHz processor and 1024 x 768 resolution. However, the eight-incher packs new Mali-400 dual-core graphics and doubles the RAM to 1GB. The bigger 9.7-inch Elite matches these, but totes a larger IPS panel at the same resolution, alongside 16GB of storage -- twice the amount found on the existing Extreme.
Storage Options pads out its budget ICS slate lineup by two -- Engadget
https://imgur.com/hwgbR
