techseeker
Hi All,I got this modem a few days back and fighting with this very odd problem. I have been through a lot number of posts on this forum and tried to fix myself but unfortunately did not find success yet. This problem uncannily also resembles exactly the problem reported by a user on linuxforums.org still unresolved.PROBLEM:Connect the laptop via LAN cable to modem goto 192.168.1.1 and do all the configurations of PPPoE in the normal way ,then goto wireless section , I did not change the SSID of default value UTStarcom , then in security I chose WPA-PSK gave it a ten digit number and associated was TKIP.Then save reboot , the wireless now gets connected and shows as connected in wireless network manager window. Very good.But now I switch off the laptop , switch off the modem ,disconnect the LAN cable and all. NOW -After sometime I switch on the modem and LEDs for DSL, Internet and WLAN are glowing.I siwtch on the Laptop , the wireless switch on the Laptop is definitely ON and I expect that atleast when I refresh the list of available wireless aces points ,I should be able to see the UTStarcom ,select it and try to connect it by typing the WPA-PSK which I saved . BUT Unfortunately the list is blank and it shows something like 'no wireless networks found in range'.Then the strange part I connect the LAN cable again between modem and laptop goto wireless secutiry and hit save/apply and then it comes in range showing as WPA secure wireless network and then it gets connected. I also then still goto management and then save/reboot .But again if I now switch off/on both and remove the LAN cable AGAIN I need to repeat the cycle .This modem was changed yesterday with a new piece ,I see the same problem.Funny part : If in security I go and change it open "which is a totally unacceptable part " and then if I switch off/on then I do not face this problem . I have really tried several permutation combination stuff from the posts but to no avail . Please help me this kind of always having to save wifi security settings everytime I siwtch on is not liveable and hence requesting experts to help out here.OS : Windows XP ,SP3Router/ Modem : UTStarcom WA3002G4DHCP enabled on laptop.DHCP settings on modem too are default and are enabled.Wireline use is perfect and no issuesEverytime after I save wirless security and then disconnects the cable the wireless after that lives on and continues but if I switch off both and switch on wireless though WLAN shows ON ,it is not detectable on Laptop AS WELL AS on mobile.Hope I have provided the details.Thanks in Advance!!
