Shashank41
I was up surfing at 6 in the morning when my net got disconnected suddenly. I use the bridge mode to connect through the ut300 r2u modem. Now since then i am stuck at connecting through wan mini port. I tried to hook up the pppoe connection via the config panel using first my default ip address and the dns 218.248.255.194 and 218.248.255.162 and the default gateway.didnt work.then i changed dns to 208.67.220 and 208.67.222.222 with default settings for gateway and ip.still didnt work.so i reverted to the dialer and have been getting error 678 the remote computer didnt respond.my snr margin is 31.3 down and up is 20.3 . I used to get low or on connectivity before also in the lan but the dialer worked fine.attenuation is 20.0 down and 8.7 up .mode is adsl2+.vpi vci 0-35 .kindly suggest what to do
